View Poll Results: How many K's do you get out of tank of fuel?
Voters
1333. You may not vote on this poll
  • 300 - 350
    62 4.65%
  • 351 - 400
    96 7.20%
  • 401 - 450
    191 14.33%
  • 451 - 500
    222 16.65%
  • 501 - 550
    254 19.05%
  • 551 - 600
    217 16.28%
  • 600 +
    291 21.83%
Results 1 to 10 of 1199
Thread: Fuel Economy - What do you get out of a tank? (3rd gens only)
    Sep 2013
    Quote Originally Posted by macropod View Post
    Conversely, there's the question of how many litres of fuel your car has used when you get to 'reserve'. On mine, the low fuel light used to switch on when there were 15 litres remaining - now it's at 25-28 litres. The latter will quite obviously result in a lower 'apparent' range. As I've said before, all these figures on what you get out of a tank are pretty meaningless (especially given differences in tank size between AWD/2WD sedans & wagons) - you need to track how many litres/100km you're using (and to differentiate between city and country driving).
    I don't go by how many litres I put in on that tank, I go by how many litres it took to refill the tank. Its usually about 60L (maybe as low as 55L) to an average of 450km. That's an optimistic 8km/L or 12.5L/100km
    A hell of a long way off some of the 10km/L or higher some people are quoting.
    Someone suggested theres a way to check if the O2 sensor is in need of replacing before actually replacing it?
    Yes, its a Mitsi! vlad's Avatar
    Jun 2003
    Quote Originally Posted by Millenium7 View Post
    Hi Millenium, isn't the bolded sentence the same? Please read my post above. Also, 55/450*100 is 12.22L/100km and 60/450*100 is 13.33L/100km. That is the range I get in my 1700kg AWD Verada GTVi doing the daily to/from work/drop kids at school weaving through suburbia and city.
    Sep 2013
    Quote Originally Posted by vlad View Post
    No, the first is the previous tank of fuel i've just gone through, the second is the tank of fuel I have just filled up with. The former estimates how much was used and how far you got from it. The latter measures how far you drove, and then measures how much fuel was needed to refill the tank to the same mark. The former is not accurate as the fuel guage and reserve light won't come on at the same mark every time, the latter is as it measure exactly how much fuel was used, not how much fuel you think was used
    Confused? I am too
    Yours is an AWD which on average will burn a significant amount more than the FWD. I would expect a good 2km/L more just because of that
    Quote Originally Posted by Jakeys View Post
    Where did you read this? First I've heard of it, I would think having the car maintain the absolute minimum output to maintain your desired speed and sitting exactly on that marker instead of the inevitable tiny ups and downs from your own foot on the pedal would yield more efficiency.
    +1, CC will be more fuel efficient on flat surfaces as it doesn't fluctuate as much. I can see it being worse on inclines though as a drive can pre-empt the hill and slowly build/scrub speed earlier. Most of what I drive is pretty flat
    macropod's Avatar
    Feb 2010
    Australian Capital Territory
    60l/450km works out at 7.5km/l (13.3l/100km). 55l/450km works out at 8.2km/l (12.2l/100km). Not too shabby for around town in an auto.
    On country trips, my TW AWD VRX can easily return 11km/l (9l/100km) or better. Around town, it's typically around 7.7-8km/l (12.5-13l/100km). FWIW, I tend to re-set the fuel metering every time I refill, so it's quite easy to keep track of the average consumption on any tankful.
    Anyone with an exhaust gas analyser should be able to check the O2 sensor's performance.
There are currently 3 users browsing this thread. (0 members and 3 guests)
